  • Announcements
duanechamblee
dishwasher cycles not advancing
3 posts in this topic
My Whirlpool DU850DWGB0 is no longer advancing the cycle knob through the cycles. ie, it doesn't move/rotate anymore.
We can manually advance the knob to the next cycle when we HEAR the finish.
I've looked around for parts and I'm guessing the CAM or timer may be the issue?
Anybody know what the problem might be?
Use your meter to see if the timer motor is getting 120vac.  If not, then we need to troubleshoot the circuit to see where we're losing voltage.
If you are getting 120v to the timer motor, then you need to replace the timer:
http://www.repairclinic.com/referral.asp?R=154&N=1057390
Thanks, I'll check out the voltage.
