Mahgetd
dishwasher won't drain
3 posts in this topic
My dishwasher will not drain.  I sounds like it is running fine.  I've disconnected the drain hose which is clear.  In fact when the hose is disconnected water will slowly drain out the part the hose is connected to.  I've removed the lower washer arm and checked for any clogs around the filter.  The float valve seems fine.  Where do I go from here?  I don't know if my dishwasher has a solinoid and valve or the motor reverses to drain.
WP 2000 GOLD
Model # GU940SCGQ
thanks,
Margaret
Time to take out the check valve and clean out the gookus:
wp_dw_check_valve.jpg?dc=4675439895431114959
Thank you Grand Master.  That was indeed the bad child.  Many, many thanks!
