chance85
Member Since 25 Dec 2006
Offline Last Active Feb 10 2015 05:29 PM
In Topic: WTW4950 SPIN ISSUE
24 September 2014 - 07:05 PM
Thanks for the reply's, wound up, tub drive spline (both tub and drive shaft) sheared.
14 September 2014 - 10:08 AM
Will have to wait on led test till I can get back to customer. Only pulled cap to verify wash plate nut was tight.
14 September 2014 - 09:35 AM
When I first checked  error codes they were as follows, f7-e1 basket speed sensor fault, f8-e5 hot cod reversed, f0-e5 off balanced load. While in the auto test mode everything passes until test 12 (motor spins) thats when the wash plate spin out of control, it doesn't look like the basket is trying to spin. While in manual test mode, select test 9 (low spin)  plate spin out of control a few times then the unit faults out (locks up).
In Topic: Samsung RF4287HARS/XAA No cool in freezer
24 April 2012 - 07:25 AM
Thanks for the reply appl.tech. Wound up being a small leak at one of the joints in the back of this unit, Had me puzzeled because fresh food compartment was nice and cool, I thougth the freezer would try to cool down some, but it stayed pretty much room temp.
In Topic: Bosch dishwasher SHY56A056C
01 June 2011 - 06:30 PM
Service manual would be very nice.
