chance85
Member Since 25 Dec 2006
Offline Last Active Mar 10 2015 12:42 PM
WTW4950 SPIN ISSUE
13 September 2014 - 10:22 AM
GREETINGS.
I HAVE A WTW4950XL2 WHIRLPOOL TOP LOAD WASHER THAT IS ACTING STRANGE. WHEN IT GETS TO THE POINT IN THE CYCLE WERE I BELIEVE IT SHOULD SPIN, IT LOOKS LIKE THE WAS PLATE SPINS OUT OF CONTROL. IF YOU PUT THE UNIT IN DIAG AND SELECT LOW SPIN, AGAIN THE WASH PLATE SPINS REALLY FAST FOR FEW SECONDS AND THEN FAULTS OUT. YOU  HAVE TO UNPLUG TO RESET UNIT. ANYONE HAVE ANY IDEAS.
THANKS
GE PST23SGNA BS
25 January 2014 - 11:51 AM
Does anyone have a procedure for replacing the water dispenser tube in the freezer door on a GE (PST223SGNA BS) refrigerator? Line froze in door and is now leaking.
Samsung RF4287HARS/XAA No cool in freezer
19 April 2012 - 05:03 PM
Has anyone had any problems with this model not cooling in the freezer compart. No frost pattern at all, appears that freon is not flowing to that evaporator. Fresh food compartment cooling ok and middle crisper drawer seems to be right temp as well. I dont think the 3 way valve is swithing properly but not real sure how to test. Anyone have any Idea's?
Bosch dishwasher SHY56A056C
01 June 2011 - 05:58 PM
I have to change a circulation pump on this Bosch dishwasher(SHY56A056C), anyone have any advise they would like to share. Bottom of these things look a little complicated to get into. Thanks.
RS277ACBP
19 May 2011 - 06:19 PM
Anyone having problems with water building up in the bottom of both compartments. Drains not stopped up, seems to be running down the inside of the evaporator covers.
Thanks.
