jahjahbinks
Member Since 25 Jun 2005
Offline Last Active Feb 08 2014 08:16 PM
#217380 Refrig actually blew up!
Posted by jahjahbinks on 13 December 2011 - 10:56 PM
this one is easy , replace the gas with 410a and when the heater kicks in 700+ psi will do the trick. p.s. 410a is also flammable
#215285 JADE Built in Refrigerator RJRS4270D - Dead - No Lights Even
Posted by jahjahbinks on 22 November 2011 - 08:09 PM
there is also a(rocker) power switch located next to the main control board on top , check that as well
#75400 Do not run oven Self-Clean cycle this close to Holiday
Posted by jahjahbinks on 10 July 2007 - 12:55 PM
what is self clean? i know the theory but after you bake your home for 3+ hrs dont you still have to hand clean the oven anyway?
