jahjahbinks
Member Since 25 Jun 2005
Offline Last Active Feb 08 2014 08:16 PM
maytag french door fresh food section freezing food
24 February 2013 - 12:06 PM
i`m trying to repair a maytag french door ref that is freezing in the fresh food section i have replaced the thermister 6 months ago temp is set to 45f however the fresh food is still freezing according to maytag i need to turn off the icemaker (what no ice?) adjust the shelves? i tried these with no results , however when the icemaker is off the temp becomes more stable the fridge is about 8 yrs old and this problem has just returned two months ago , will it ever end? i have searched the fourms and haven`t found any solutions to this problem,
fisher paykel od302-ss-usa top oven not working
14 February 2012 - 01:47 PM
intresting problem this one is having , the top oven not working, o.k heres the skinny.
set the oven to aero bake no heat from the fan element or the bake element but the unit stays in the on and running position, set the unit to bake and the unit first blinks out then returns on in the waiting to select upper or lower oven mode .second try on just bake then the unit just cancells the call for the upper oven .third try on just bake and it cancels the upper oven out again.by this call being under 3rd party warranty the fan element is getting replaced anyway i have encountered this before but the the auto cancel and the blinking out is new. previously i have ordered relay boards for this model only to recieve boards that are missing places to plug things into (like sensor) or (light switch) and these parts came from fisher paykel . I will shotgun it if i have to but i really rather repair it quickly.
MFI2569VEM1 maytag bottom freezer top section too cold
05 February 2012 - 07:38 PM
customer has a MFI2569VEM1 maytag three door ref and the top section is too cold , my best guess is the thermister sence there only one for the ref section i would like to know your thoughts, temp settings are freezer 0 ref 38
dacor double oven cps227 stops running
28 November 2011 - 02:29 PM
i have a dacor cps227 double oven that won`t run both ovens at the same time the main relay board was replaced to correct the F1 constance beeping ,worked for 1 day and returned now the problem is both ovens won`t work at the same time (one oven just shuts off) then F1 again the upper oven according to the service chart f1 is element relay circut failure, (replaced 1 week ago) @$200+ , each oven will work one at a time but not together the only code is F1 what am i missing? no help from dacor (not suprised)
question #2 if it takes 2 men to test this machine ? why keep it ?
viking dedo130ss parts list
20 July 2011 - 11:36 PM
any idea on where to locate a parts list for a viking dedo130ss , odd as it may be new construction app and its disconntinued model already , came all beatup and the ref all dented and no manuals and a 6hr hold from viking ,and i thought thermador was slow, any sublime wisdom will help :)
