kbissing
Member Since 11 Jan 2007
Offline Last Active Feb 23 2015 10:15 PM
Uline clr2160 ice maker not stopping ice production
22 July 2014 - 07:10 PM
My ice maker seems to be producing too much ice. I am not sure what is wrong. It is past the overflow tray and shows no signs of stopping! Help!
Kim
ULine CLR2160 won't start clean mode
23 April 2014 - 07:43 PM
I have followed the directions in the manual but still cannot get it to start clean mode!
Pushed in On-Off button, pressed light button 3 times.  It's not starting clean cycle.  Help!
Brant boiler bw2aan00140aaaa negative air flow?..switch keeps going out
12 January 2012 - 12:05 AM
We bought a 100 year old home and did extensive addition. New addition has 2-45 gallon water heaters, gas forced furnace for new addition. Old part of house is heated by boiler.
Remodeled kitchen and added cooktop with exhaust fan which is brand new and vents through attic.
We moved in and almost immediately boiler coupler went out. Told we have negative air pressure in home now because we replaced windows, roof, etc. So we added a equipment room (framed and drywalled) with an open window constantly in that room. Door is always shut so if boiler needs heat when starting it pulls from outside air.
That doesn't seem to be working. Small piece has been replaced that causes boiler to shut off when air is not released. This has went out twice since November. First time we thought because we left the mech room door open and ran fan on stove. This time, everything was closed And fan was not run.
I'm at my wits end! Any suggestions welcome, including calling in another te h for another opinion.
Hunter Fan Remote Lite Control 27185
17 January 2010 - 04:33 PM
My husband installed the remote lite control kit to our existing hunter fan that was a pull chain.  (worked succesfully w/ the pull chain light and fan previously)
We are able to use the remote to turn on/off the light and fan but it goes off and on at various times for no apparent reason.  do you have any suggestions?
FRS23H5ASB6 Frigidare Refrigerator stuck on crush ice
12 January 2010 - 04:20 PM
The switch on the front of the refrigerator works (allows me to press Crush or Cube) and the light switches back and forth but only CRUSH comes out.  Do you know the part number I need to replace?
Thanks,
Crying over crushed cubes in Chicago
