Scottthewolf
Member Since 01 Feb 2007
Offline Last Active May 25 2015 02:05 PM
#249374 Maytag Bravo washer model# loud roar during spin, tub bearing replacement
Posted by Scottthewolf on 02 March 2013 - 12:36 AM
That's why when I do these, I just order the outer tub and the inner wash basket and don't waste my time trying to pull the inner basket out.  Hell with the stupid bearing kit
#249346 Kenmore Laundry Center
Posted by Scottthewolf on 01 March 2013 - 08:36 PM
Did you test item #36 for continuity? It's located on the rear panel inside the dryer and is easily overlooked because it's not  on the heater housing.
http://www.repaircli...4120900/1489053
http://commercial.se...10065-00001.png
#249330 Bosch Dishwasher - Heating Issue. Model SHU33A02UC/38
Posted by Scottthewolf on 01 March 2013 - 06:24 PM
Most common problem on these is the control module, look for a burnt heater relay or burnt solder joint.  Some of these dishwashers are covered under a recall, I need your serial number to find if  this dishwasher is covered under the recall.
#249279 Scavenger hunt KitchenAid KUDA03CTWH3
Posted by Scottthewolf on 28 February 2013 - 11:24 PM
KUDA03CTWH3=http://www.whirlpool...ame=KUDA03CTBL3
KUDL01ILBS2=http://www.whirlpool...ame=KUDL01ILBS2
#249278 Maytag Bravo washer model# loud roar during spin, tub bearing replacement
Posted by Scottthewolf on 28 February 2013 - 11:18 PM
Model number should be MVWX500XLO. Tommytech was missing the X after the W.
#249277 maytag bravos m#MVW500XLO
Posted by Scottthewolf on 28 February 2013 - 11:12 PM
It should be MVWX500XL0.
#249258 110.92591200 Motor
Posted by Scottthewolf on 28 February 2013 - 05:14 PM
Almost sounds like a bad capacitor.
http://www.repaircli...8572720/1180742
#249254 frigidaire dryer gleq2152es1
Posted by Scottthewolf on 28 February 2013 - 04:26 PM
Turn the big knob ( the cycle selector) to the DELICATES cycle.
#249249 MAYTAG WASHER (LAT8826AAE) Extra Rinse Cycle
Posted by Scottthewolf on 28 February 2013 - 02:31 PM
Did you test that button switch for continuity with your meter?  With the button pressed in and on, it should show continuity and the meter should beep,  with the button out and off you should get nothing and no beep. If  the switch tests good, your problem is the timer.
#249239 208V For 240V Dryers
Posted by Scottthewolf on 28 February 2013 - 01:06 PM
Samsung dryers in particular are known for going through heater assemblies.
#249238 frigidaire dryer gleq2152es1
Posted by Scottthewolf on 28 February 2013 - 01:01 PM
Most likely a bad electronic control board.
http://www.repaircli...4523200/1154933
#249153 Frigidaire FWT449GFS1 door boot removal
Posted by Scottthewolf on 27 February 2013 - 12:26 AM
You will have to replace the door boot once you cut the old one off. WHY do you want to take the machine apart?
Here is the correct service manual for your machine.
Page 75 explains how to install the new door boot.
http://www.emaservic...tionWashers.pdf
#249151 Roper dryers RED4440WQ1 & RED4440?(421)
Posted by Scottthewolf on 27 February 2013 - 12:17 AM
Remind your customers only to turn the timer dial clockwise.  Turning the timer dial counterclockwise ruins the timers.
#248995 Amana leak
Posted by Scottthewolf on 23 February 2013 - 02:08 AM
2 things to check for:  What was the part number of the belt you installed and is the inner wash basket spinning while it's agitating?  If the inner wash basket is spinning while it's agitating, the brake pads might be worn from the bad helix. The brake not holding the inner wash basket stationary during agitation could be splashing the water over the tub. The incorrect belt could also be causing the water to splash over the tub during spin.
#248929 GE Refrigerator GTH18XCTZRWW
Posted by Scottthewolf on 21 February 2013 - 11:01 PM
I have caught all brands of refrigerators where the defrost control board keeps the unit in defrost too long or  keeps the defrost heater on when the compressor is running.
