bydge
Member Since 04 Feb 2007
Offline Last Active Apr 17 2012 04:35 PM
In Topic: Whirlpool Dishwasher DU941PWKQ1
17 April 2012 - 04:06 PM
Gotcha. I took off the drain hose and water flows freely from the check valve when the dishwasher is full. I blew threw the drain hose and I am about to re-attach it and see if it works. I will let youknow what happens. Thanks.
17 April 2012 - 03:40 PM
Should I disconnect the drain hose from the dishwasher or from the garbage disposal end?
In Topic: Separating a Agitator
27 December 2010 - 12:37 PM
Thank you, Sensei. It worked!!! I will post if I have any other questions. Thanks again.
