Frumby
Member Since 02 Mar 2007
Offline Last Active Nov 01 2014 03:25 PM
In Topic: Samsung RFG296HDPN Freezer Drawer Ice Maker
01 September 2014 - 07:18 PM
Ordered the part! As always, Thank you!
In Topic: Ice maker producing very little ice
22 August 2013 - 08:10 PM
Temperature is at 21 degrees. The ice maker does have ice but the ice does not appear to be fully formed...."almost" is a better description. The water line is not frozen.....ideas?
In Topic: Whirlpool Duet HT Front loader (9 years old) flooding
03 January 2013 - 07:11 AM
Thanks gentlemen. I've ordered the part and it is on the way. I actually thought that it was drain pump not working. Obviously misdiagnosed when the washer had not been used in over a day and water began leaking from the door. Just another lesson learned. Thank you again.
The Colonel
02 January 2013 - 07:16 PM
Sorry, I should have known better:  Model #GHW9400PL0
In Topic: Whirlpool Duet Ht Washer Drain Issues
12 December 2012 - 07:25 PM
Thanks for the help gentlemen.  I took the entire hose drain assembly apart and found some lint gumming up the stop valve ball (I'm assuming that prevents water from backing up into the washer).  Apparently, the lint was not allowing the ball to drop completely so water was remaining trapped inside the washer.  I've run 5 cycles without a problem.  Going to try a load of towels and see what happens.  Thank you again.  Semper Fi!
