reeferman
Member Since 02 Mar 2007
Offline Last Active Jul 01 2015 11:09 PM
In Topic: Kitchen Aid Dishwasher KUDE70FX leak at diverter motor - known issue?
01 July 2015 - 10:11 PM
Can you post the results of Allstate going after K. Aid? Thanks.
In Topic: Whirlpool/Kenmore Direct Drive NO pause drain Model 110.23812100
11 June 2015 - 10:40 AM
I have the exact same problem with my 110.20222990. It seldom pauses after the two minute mark. I'm ordering a timer based on the above posts. Kudos to Ram for following up with the solution.
In Topic: Frigidaire Dishwasher FDB710LCS0 timer stalled at 7 o'clock
20 May 2015 - 03:46 PM
Well.....shiver me timbers, it is the thermostat up front and on the right. Now I have to determine: is it the control, or the assure/boost thermostat?
I have one in my toolbox but not sure what type. Weird how it doesn't show up on any diagrams. I thought I had seen it somewhere but now cannot remember...
15 May 2015 - 12:01 PM
I'll go back and check that t-stat again. I have to pull the bloody unit out and tip it back a little to get to them. Thanks Chat.
21 April 2015 - 04:20 PM
Yes on both. It will advance to end of cycle if manually advanced to past 7 o'clock, one or two small clicks.
Soap door opens (at around 5/6 o'clock) and water valve works. The dishwasher just sits there in wash cycle.
I noticed the "wash" indicator light goes off and on throughout entire cycle, yet it stays off at 7 o'clock and the dishwasher just sits there in wash cycle.. That's why I am suspecting the timer. I'm going to use an ohmmeter and the tech sheet (which I located on this website by following the Samurai's instruction on how to search) and try to isolate the bad contact within the timer. I'm thinking the small amount of resistance on the blackened wire terminal at the hi limit thermostat may have caused an arc to jump at that point, inside the timer, seeing as the thermostat has been identified in other welcome posts by other members as a common culprit on this particular "mechanically timed" appliance. I'll post a follow up on this afterwards.
Also, I think I saw your likeness in a movie preview coming out in December. You haven't aged a bit. Thanks Wes.
