Comstock_Services
Member Since 06 Mar 2007
Offline Last Active Mar 14 2013 01:20 PM
kgra806pss00
26 January 2013 - 10:52 AM
Ok I have a Dual Fuel range runs on 120v and gas. The gas portion of the oven comes on but only for 3-30 seconds. and maybe 2 times during preheat. it has a gas and electric broil element, and the electric broil elemnt seems to be doing most of the preheating. The ignitors are tied to a spark module like the Pizo? ignitors on top of a cooktop, not globar ignitors. any ideas where to start would be a great help as I'm currently stumped.
Mr Appliance of the Costal Bend Corpus Christi Area
16 January 2013 - 12:15 PM
We are a full service appliance repair shop that comes to you. You can contact us at 361-371-3240. We Charge reasonable rates and have a large service area. You can Schedule on line at http://www.mrappliance.com/coastalbend. Thank you for your consideration.
LG WM2277HW washer leaking
03 January 2012 - 06:09 PM
On both of these washers the mushroom vavle, check valve, is present in the vent, WH2277HW is production of 09 if i read it right. I observed oversuds condition, and ASSUMED that that was what was causing the leak. Through diagnostics, the unit checks good for everything but recirculate. I.E. I couln't tell if it was moving the water or not, in the given portion of the test cycle. I'm open for any suggestions, and I proably should have searched before posting this thread, Thanks in Advance.
More side notes, the customer is using powdered, tide, non HE, I'm going to call this in shortly as a denial of coverage, unless some wisdom can be shown to me. I know that the vent is designed, to leak, during heavy suds, and mostly to help the machine, during drain.
Scottsman Ice Machine DCE33A-1WB
28 December 2011 - 08:55 PM
I've got a scottsman ice machince that will cycle properly, but will not form ice in the evaporator. I was wondering what temp the unit should be at to make ice? I don't work on many of these, but it seems to me that there is an issue with the cube size control. I say this because the water cools down to about 37-38f.
Dryer Vent tester works with most brands
24 December 2011 - 01:22 AM
I have one of these babies, and its great for illistrating a partially clogged vent to a customer. http://www.repaircli...0106710/1447456
