JJVBVA
Member Since 12 Mar 2007
Offline Last Active Aug 22 2013 11:54 AM
In Topic: Imperial IR60 - Replacing Oven Manual Igniter Button
18 August 2013 - 03:42 PM
Bump. I didn't think this was a tough one. I plan to splice into one in unless I hear to the contrary.
In Topic: Replacement for A.O. Smith FSG 40 222?
24 June 2011 - 07:41 AM
Thank you. I will be able to get exact specs off the existing one later today so I can match up the replacement better. I spent some time searching unsuccessfully for specs on the existing unit on the internet. I've not done one of these before but it looks pretty straightforward. Just trying to minimize making mods. Primarily would like to keep the exhaust and gas line intact. Plumbing is not a big issue if I need to change them a bit.
In Topic: Kenmore Electric Dryer - Model 110.66912691 - No Hot Heat
08 January 2009 - 07:38 AM
Not sure exactly what I did, but it is working now.  I checked the voltage at both sides of the fuse and it was OK.  In the process of checking other connections, I shorted the power out and had to reset the breaker.  I rechecked all connections and ran it again.  Noticed the element glowing.  Thanks for the assistance.
01 January 2009 - 02:10 AM
Thanks for the tips.  I will follow-up next week when I return to the machine's location and can run these checks.
31 December 2008 - 04:20 AM
Checked the terminals.  All clean, nothing unusual.  Power at 240 into the machine.  Any suggestions?  Thank you.
