BrntToast
Member Since 14 Mar 2007
Offline Last Active Nov 23 2014 05:32 PM
In Topic: Maytag Vacuum Cleaner
16 October 2014 - 09:07 PM
hrm, sure hope we dont start seeing vaccuum calls   :/
customer "my maytag vaccuum doesn't suck"
me " one second, i'll get a GE logo to put on it,then it will really suck"   :P
In Topic: kenmore 11047512605
16 October 2014 - 08:18 PM
yeah, i have to go back and check the resistance of that sensor once my new meter arrives
some #$%#! stole my tools last week,i'm just using a cheap 10 dollar one till my new one arrives
In Topic: Frigidaire washer ATF6000FS0
15 October 2014 - 10:22 PM
remove back panel, speed board is on the base,on the right hand side
grasp the drum from the back, pull it towards that board,watch where it may contact that board
see if there is any wiring is routed in that spot,if so, check those wires for breaks or pinch marks
In Topic: 110.82822102 dryer -- eats boards?
06 October 2014 - 08:55 PM
you never mentioned if you checked the heater to make sure it is not shorted to ground
In Topic: Frigidaire shutting off after 10 secs. throwing error 62 model FEQ1442ES0
05 October 2014 - 07:53 PM
code is prolly e63
heater to earth ground
