BrntToast
Member Since 14 Mar 2007
Offline Last Active Nov 23 2014 05:32 PM
#305782 Maytag Vacuum Cleaner
Posted by BrntToast on 16 October 2014 - 09:07 PM
hrm, sure hope we dont start seeing vaccuum calls   :/
customer "my maytag vaccuum doesn't suck"
me " one second, i'll get a GE logo to put on it,then it will really suck"   :P
#305710 Frigidaire washer ATF6000FS0
Posted by BrntToast on 15 October 2014 - 10:22 PM
remove back panel, speed board is on the base,on the right hand side
grasp the drum from the back, pull it towards that board,watch where it may contact that board
see if there is any wiring is routed in that spot,if so, check those wires for breaks or pinch marks
#304907 Frigidaire shutting off after 10 secs. throwing error 62 model FEQ1442ES0
Posted by BrntToast on 05 October 2014 - 07:53 PM
code is prolly e63
heater to earth ground
#304905 Frigidaire shutting off after 10 secs. throwing error 62 model FEQ1442ES0
Posted by BrntToast on 05 October 2014 - 07:45 PM
check heater to ground, e6* are heat issues, and if it does it on start up. its prolly something in the heater circuit that is grounded.
crappy heater in that machine, the frame that holds the heater in place tends to warp, causing the heater to touch the heater housing.
if you find a grounded heater on these machines, after changing the heater, always run the machine on air fluff, just to ensure the contacts on the heater relay are not fused, seen it a few times already
#304281 Fridgidaire Front Load washer won't spin (LAF3511KW0)
Posted by BrntToast on 26 September 2014 - 10:50 PM
yeah,thats the board on the left, you need to look at any wiring that may have been smashed by tub movement, you prolly have a broken wire inside the insulation
#304072 LG Dishwasher LDF7551ST making noise
Posted by BrntToast on 24 September 2014 - 06:43 PM
11 days past warranty?  do you mean one year?  cause if so... you have 2 years on parts, and 10 years on the motor(which is a likely cause of a high whistle)
MANUFACTURER'S WARRANTY SUMMARY
Period of Coverage
Labor : 1 Year
Parts : 2 Years
Extended : 5 Years on Control Board and Rack parts and the Stainless Steel Tub or Liner, and 10 Years on DirectDrive™ Motor
#304067 Whirlpool gx5shdxvq02 JAZZ Board part change
Posted by BrntToast on 24 September 2014 - 06:12 PM
change i noticed.... no instructions in the box for programming, this will cause some grief for DIY'rs
#301182 Frigidaire Professional Dishwasher Model #FPHD2491KF0
Posted by BrntToast on 17 August 2014 - 09:48 AM
it appears the heater thermostat is in series with the neutral line,  check for a open heater circuit,  rinse cycles dont heat water,all other cycles do, so this may be a cause for only rinse running the wash motor
#296820 Random Sparking when Burners are off (Kenmore Gas Range Model# 79078511401)
Posted by BrntToast on 21 June 2014 - 09:45 AM
you say you renovated,any chance the wiring to the range could have been damaged during reno ?
try running an extension cord from a different outlet to the range for a day or so and see if the sparking continues
i'm with the samurai, random sparking can be bad/reversed supply voltage
#296171 Help with diag on Frigidaire side by side phs68ejsbo
Posted by BrntToast on 11 June 2014 - 05:57 PM
Frigidaire 2004 SxS Refrigerator with Genesis Controls
this manual is for both mechanical controls and the lovely genesis controls you have
you say the freezer is cold and you can feel a fan blowing into the FF compartment?
cause really,you should have cooling in the FF section then. unless.... something is blocking the return air vent behind the bottom crisper,remove that crisper and make sure nothing has fallen down there blocking the return vent(the fan will "blow" with the doors open, but soon as the doors are closed,the fan will not be able to circulate air between the 2 compartments
after that i'd be looking for proper damper operation
that manual page is open for public viewing and contains most older friggy manuals if you ever need one again
#295124 frigidaire front load won't spin
Posted by BrntToast on 01 June 2014 - 11:38 AM
i didn't know friggy had an out of balance signal
first thing you can do is remove the lid and back panel, there will be a tech sheet either on the top of the dispensor,or taped to the inside of the cabinet
try to run the diagnostics
carefull around the opening of the back panel, its very sharp
also.... while behind the machine with back panel off, grasp tub and rock it towards the white motor board, watch to see if the tub can come into contact with any of the wining harness,inspect that harness very closely looking for broken or crushed wires(the fine wires can get crushed,the wire breaks inside the insulation)
#295004 Electrolux Stacked washer FTF530FS1
Posted by BrntToast on 30 May 2014 - 05:20 PM
step one, place machine in the spin cycle,wait 2 minutes(wether it spins or not)
now unplug the washer and try to open the door
if the door opens instantly, you need a door lock
#294914 washer is going crazy Kenmore 417.40412700
Posted by BrntToast on 29 May 2014 - 10:23 PM
kenmore model 417.....  made by frigidaire
you say you caught the machine filling and draining endlessly?
known frigidaire problem
you need a speed board, also called the motor control unit
and yup a bad speed board can do all sorts of flakey stuff
another symptom ....  timer knob gets stuck at around the 5 o'clock position
another common problem i saw with these machines.... the tub can go out of balance bad enough to smash into the bottom of the timer.
Remove washer lid, closely examine the bottom of the timer and where that molex plug connects there, look to see if it looks squashed or out of place
but filling and running the drain pump forever is the speed board for sure
frigidaire blamed this on electrical interferance comming from other outside sources, they say they modified later boards to prevent this
this was like 10 years ago or so
#294776 Rattle in Whirlpool duet washer wfw8640bw
Posted by BrntToast on 28 May 2014 - 05:17 PM
you cant really see between the spin basket/front drum very well
removing the bellows from the tubs gives a lil more room
last time i had the problem you describe, it was a dice, had been left in a pocket,made it in there,but not past the lip of the spin basket
#294774 Vintage 60's GE P7 Electric Range with Double Oven
Posted by BrntToast on 28 May 2014 - 05:06 PM
check the fuses, they are under the top cover or the trim where the utility plug is
the oven ones are 30amp(green)
you cant tell by looking at a fuse,need a meter,or a new fuse to test them
after fuses you will pull the unit out and remove the back panels looking for burnt wires in the control panel
