BrntToast
Member Since 14 Mar 2007
Offline Last Active Nov 23 2014 05:32 PM
kenmore 11047512605
15 October 2014 - 11:02 PM
machine has a stored f24 error(water heating error)
checked the connections to the temp sensor,and all the wires in the strain reliefs
now here is the question for the dojo
this model has a sanitize option,and a extra hot water option
but it does not have a heater?
am i missing something here?
ymhwe301yg00 bellows
26 September 2014 - 10:00 PM
cust reports bellows came off the clamp
have not run the call, its from a site i post on
anyone with whirlpool access, is this a unit that requires the new inner door?
LG electric range recall
24 February 2013 - 08:49 PM
The burners on the electric ranges can fail to turn off after being
switched off or the temperature setting can increase unexpectedly during
use, posing burn and fire hazards to consumers.
The recall only includes the following models which were manufactured between October 2005 and June 2009.
    For USA: LRE30451, LRE30453, LRE30755, LRE30757, and LRE30955ST
    For Canada: LSB5611, LSB5682, LSC5622, LSC5633, LSC5674, LSC5683, LST5601, LST5651
down time?
27 November 2010 - 08:26 PM
is the downtime gettin better or worse?
i have yet to have a problem joining or using the forum
electrolux branded dishwasher with poor cleaning
21 November 2010 - 05:58 AM
if your electrolux dishwasher is not cutting the mustard and the serial numbers fall within this range
TH801xxxxx - TH934xxxxx  you require service kit 154791501
you are elligable for a filter upgrade, its free even if you are past your first year warranty, but repair must be done by an authorized frigidaire warranty depot
tell the servicer to read service buliten dw1001, it describes how they can process this work under warranty after the one year warranty has expired
i finally did this upgrade to mine at home, the very next load the wife first hugged me,cause she didn't have to reload half the *clean* dishes to be rewashed, then she kicked my A$$, for not doing it 6 months ago
now all i have to do is the "teenager dish loading upgrade" and i'm all set(not covered under warranty)
this message has been brought to you by your friendly neighborhood Friggyman
