GuidofromCT
Member Since 12 Apr 2005
Offline Last Active Apr 15 2015 06:30 AM
In Topic: GE Mono Refer ZSFB23DNA SS freezing water line in door?
15 March 2015 - 08:47 PM
If this is a metal liner model there is a dispenser heater kit available that may correct the freezing issue. Part number: WR49X10173
This is a relatively inexpensive repair but always tell the consumer that it is not 100% and the door may need to be replaced if the heater does not correct the issue.
In Topic: GE - GTUP270GM0WW Vertical stack combo W/D 'overflow' units fills,...
15 March 2015 - 07:43 PM
Nearly every one of these that exhibits this type of failure needs the pressure switch replaced. This is a VERY common problem with this machine.
In Topic: GLWN2800D0WS Washer Over Flow?
15 March 2015 - 01:57 PM
you may also want to check the hose which connects to the tube for the water level that is connected to the washer tub - sometimes it will be clogged or partially clogged with a black gook that will interfere with the water level sensor correctly measuring the amount of water in the tub-
