dmanleysr
Member Since 06 Apr 2007
Offline Last Active May 08 2015 08:01 PM
In Topic: Whirlpool WRF560SEYM00 no defrost.
29 October 2014 - 04:47 PM
Replacing main control board resolved the problem.
13 September 2014 - 09:36 AM
No failure conditions at step 17.
In Topic: LG Washer WM2016CW Won't start.
07 May 2013 - 07:17 PM
Just as I had thought "Bad Door Lock". Test point 2 to 4 should be 700 to 1500 Ω. It was open. I never realized that there were two different versions of that Service Manual. Doesn't make sense. Thanks again for your help.
07 May 2013 - 09:44 AM
Scott,
Thank you very much. Just what I was looking for. I also have WM2016CW Service Manual and it doesn't have these pages. Pagers are numbered (1-40). Cover page is identical. Go figure.
In Topic: Asko Washer W6021 Won't Fill
12 March 2010 - 09:55 AM
Replaced water level switch and motor brushes. Fills and works fine. Installed old circuit and unit works fine.
