dmanleysr
Member Since 06 Apr 2007
Offline Last Active May 08 2015 08:01 PM
#254054 LG Washer WM2016CW Won't start.
Posted by dmanleysr on 07 May 2013 - 07:17 PM
Just as I had thought "Bad Door Lock". Test point 2 to 4 should be 700 to 1500 Ω. It was open. I never realized that there were two different versions of that Service Manual. Doesn't make sense. Thanks again for your help.
#253916 LG Washer WM2016CW Won't start.
Posted by dmanleysr on 06 May 2013 - 01:29 PM
Power on. Select wash cycle screen shows - - -. Press start/pause button nothing happens. Enter QC test mode screen flashes IU02 and then In80 alternatingly. I can hear the door lock trying to lock 2 clicks and then 2 more clicks. Then it chimes like 4 to 6 times. Press start/pause button nothing happens. Could this be a bad lock assembly? The machine shows no codes.
