dmanleysr
Member Since 06 Apr 2007
Offline Last Active Aug 25 2015 10:24 AM
MBF2258XEB1 Maytag Refrigerator
24 October 2014 - 04:44 PM
I can not find part numbers anywhere for the freezer or fresh food section thermistors listed anywhere. Any help would be greatly appreciated.
Whirlpool WRF560SEYM00 no defrost.
12 September 2014 - 11:50 AM
Evaporator completely frozen over. Ran through diagnostics and everything checks OK and No failure condition. With diagnostics on step 5 I get 120vac at P2-7 and P1-2. The heater ohms out at 30 ohms. I was able to defrost the unit by selecting step 5 three times. My question is if all checks according to diagnostics, does that indicate that there is a problem with the main board?
Samsung Washer WF203ANWXAA won't drain error code ND
28 July 2014 - 07:33 PM
Pump and hoses are clean and open. No 120 volts to pump. In the quick test mode on occasion when I press the Signal button it will go into pump out and empty the tub like normal, but not every time. When in a wash cycle it won't pump out and gives the ND error. EEprom Clear Check = GOOD. What would cause no voltage to the drain pump and how can I verify this?
LG Washer WM2016CW Won't start.
06 May 2013 - 01:29 PM
Power on. Select wash cycle screen shows - - -. Press start/pause button nothing happens. Enter QC test mode screen flashes IU02 and then In80 alternatingly. I can hear the door lock trying to lock 2 clicks and then 2 more clicks. Then it chimes like 4 to 6 times. Press start/pause button nothing happens. Could this be a bad lock assembly? The machine shows no codes.
Newburgh, NY New Windsor, NY Cornwall, NY
08 September 2012 - 05:43 PM
Servicing all home appliances. Refrigeration & Air Conditioning. Lawn & Garden equipment. Authorized treadmill service provider. Garage doors & opener repairs.
Phone 845-564-6265
Cell 845-863-5250
Email Quality_Home_Service@verizon.net
