dahbrown
Member Since 16 Jul 2005
Offline Last Active Sep 07 2014 07:11 PM
In Topic: Technika TDX6SS-2 Repair Manual
16 November 2013 - 03:04 AM
Confirmed there was no water on the bottom of the machine. The spray arm moves freely.
When turning the machine on, it makes a humming/whirring noise. No beeping. Sounds like it is mid cycle and not filling up.
After instructions on how to reset the machine.
Thanks
One more thing, the light above the 'normal' just flashes.
In Topic: Fisher and Paykel ED56 Dryer Rubbing Noise
24 March 2013 - 04:08 AM
Thanks for your prompt reply.
Once I pull apart the dryer would it be obvious by wear & tear what I need to fix?
If it is either the bearings or the tension pulleys would they need to be replace or adjusted or sprayed?
