miruton
Member Since 14 Apr 2007
Offline Last Active Feb 21 2015 01:19 PM
In Topic: continuously running refrigerator
05 September 2013 - 11:33 PM
Interestingly, when turning the cold setting knob to a lower number (from 3 to 1) the motor would not turn off! Only when turned to the off position did the motor shut down.
05 September 2013 - 02:34 AM
Freezer temperature was about 8 degrees and the refrigerator temp measured 36 degrees.  I will check the evaporator frost pattern asaic, and post findings.
