torchkeeper
Member Since 16 Apr 2005
Offline Last Active May 20 2014 06:21 PM
#293999 short cycleing furnace
Posted by torchkeeper on 18 May 2014 - 08:00 PM
New camera on order, It`s a modular so all sheet \rock ,wiring and plunbing,  cabiniets, toilets come pre-installed. Has a loft second floor, flooring and insulation already down. Roof is hinged and crane does a lift ,kneewall hinges down and second half of roof folds over again.! You know I have all set - day photos on card from old dead camera. Tomorrow I will see if I can get some uploaded.
Thanks for hanging in with me guys. What fun would a simple problem be !!!
#245490 nnordyne g6rc
Posted by torchkeeper on 03 January 2013 - 04:30 PM
Alright, The verdict is in: No hardware problems. The crossovers in inshot burners had surface corrosion blocking the 2nd burner from catching flame. Lighting from bottom burner by hand at moment of hsi ignition of top burner lit the 3 lower burners and then would confirm flame as per sensor rod. Removed and bead blasted burners. All is fine except she started to short-cycle. Condensate was not comming out of header box fast enough. Daveb 1972 held my hand through all this and was even good enough to call me to help !!  He suggested adding a couple degrees pitch to furnace case to help drainage. It is originally a updraft unit so the condensate needed field made drainage.  That was all it needed. Corroded crossovers and too little pitch was all that was wrong. No parts needed. Cannot say thank you too all who stayed with me on this. And a shoutout to Dave. All really caused by furnace being in a damp crawlspace.
Thank you guys !!
#242913 nnordyne g6rc
Posted by torchkeeper on 21 November 2012 - 04:39 PM
could gas valve be bad ? If soIenoids in valve are weak they would not hold valve open long enough to prove flame. Only hear one click from valve? Looks likr 2 sets of windings inside valve. How do I know if valves are opening and have enough current to stay open? I have 24 volts when valve opens then .click valve shuts no more voltage. Why does valve not stay open for more than 1-2- seconds? manual says 6 seconds to prove flame? Control board or gas valve?
