Tronicsmasta
Member Since 30 May 2007
Offline Last Active Jun 18 2015 10:49 AM
In Topic: FRIDGIDAIRE F/L FWT647GHS1 GALLERY NO SPIN, DOOR OK
02 March 2014 - 03:08 AM
Make sure during testing of the unit to start before the spin mark. I have had plenty of these where you place the indicator right on the spin mark and all it does is start tumbling lock the door then skips the spin. Also make sure the extra rinse is off. If all else fails it's either a timer or speed controller.
In Topic: Jenn air cooktop jed8430adb
02 March 2014 - 12:06 AM
Man I hate to say it but you need to call an electrician... you need 4 wires there and a double breaker. White, red, black, and green. Or 3 wire install red white and black. It's a 220v appliance. End of story. It won't run properly or safely on 120v
In Topic: Electrolux dishwasher edw5505ess3
01 March 2014 - 11:01 PM
Well it looks like your using a frigidaire sump and a whirlpool seal?? im confused
In Topic: GE Gas oven JGSP48c0h1cc looking for part
01 March 2014 - 10:19 PM
Thanks
In Topic: Whirlpool WFW9600TW01 F35
01 March 2014 - 10:11 PM
F20 is a filling error. Is the water flow through the valve good? If so you may have an issue with the pressure switch hose (leaking air or clogged) or clogs in the air pressure chamber at the bottom of the tub where the black hose connects.
Oh and you could have done what I did... I bent a pin when installing the board after the APS did not fix the f35 and bent a terminal on the harness... chased my tail for about a week or two.. tried the main board again, APS again, steamer board twice until I saw the bent pin and got very embarrassed
