Tronicsmasta
Member Since 30 May 2007
Offline Last Active Mar 02 2014 03:06 AM
Bosch HBN456AUC Wiring Diagram/manual
17 June 2012 - 12:26 AM
Hey guys
I am lookin for a wiring diagram or service manual for this HBN456AUC double wall oven . The door lock motor will not rotate when temp reaches 550 degrees and at 580 degrees it shuts off... lower oven works fine in self clean... the local guys took it with them and the bosch site does not have a wiring diagram on it so I don't even know how it works lol...
thanks!
UV dye dryer vs UV dye injection
15 June 2012 - 01:13 PM
I wanted some thoughts on using the dye dyer vs using uv dye injection method for leak detection... Thanks
Q
Kitchenaid Fridge KSBP25FKSS01
15 November 2011 - 01:46 AM
'ello,
Ok this is driving me nuts.
Customer Complaint:
Crushed ice only from door. No water from dispenser. Plenty of ice.
Found 3 wires cut at the lower door hinge.(Blue, White/red, Violet) I repaired the broken wires and got the water dispenser and crushed/cubed working. Somewhere while repairing, I shorted the Blue wire to ground... saw some sparks *oops i let some smoke out*... now I have no auger motor or selenoid... Its kind of driving me crazy... any ideas?
Also, I have no idea how to get off the outer dispenser assembly off so I can check the switches in the door...
This model DOES have the optional dispenser lock and optional light switch...
I have wiring diagram for those who want to see it...
thanks!
Q
Samsung RS2530BBP/XAA
13 November 2011 - 02:39 PM
If anyone can get this service manual I would appreciate it :)
Thanks in advance.
PB975SPSS service manual
16 October 2010 - 06:54 PM
may i please have the service manual for PB975SPSS
its for this post
http://applianceguru...rum1/27972.html
