bpickett
Member Since 10 Jun 2007
Offline Last Active Oct 24 2012 10:53 AM
Frigidaire Gallery FSE447GHS0 will not start
22 October 2012 - 01:59 PM
Just replaced motor, door switch and timer in August and the dryer has worked great until today when it stopped working midway through a cycle. It will not restart. Checked for loose connections that may have worked loose from my earlier repair and all connections seem to be intact. Any help is greatly appreciated.
Frigidaire Gallery Dryer has multiple issues
10 August 2012 - 12:14 PM
My nearly 10 year old Frigidaire dryer seems to be on it's last leg, but because it's a stacked unit we would have to replace both washer and dryer to keep it in the existing space in our laundry room, since the newer units will not stack on the washer. Therefore I'm trying to fix it and looking for some solutions.
1.) The dryer continues through it's cycle regardless if the door is open or not, door light will go on and off but the dryer continues to tumble. When the dryer reaches the end of a cycle the buzzer will run indefinitely. The only way to stop it is to unplug the machine.
2.) Although the dryer cycle continues the dryer itself, heat and tumbling stops intermittently throughout the cycle but because the cycle continues it will start back after being shut down for 10-20 minutes. Just before stopping, the dryer begins to slow down and, loudly, strains to a stop.
Thanks in advance for any assistance in resolving these problems.
