Jaks69
Member Since 18 Jun 2007
Offline Last Active Feb 14 2013 12:02 PM
In Topic: Armstrong SX 80 Blower Issue
29 January 2013 - 09:21 AM
Measured the EFT terminal, no voltage. Changed out Smart Valve (Gas), everything fired like it should. All Fixed! Thanks for the input on this.
28 January 2013 - 03:24 PM
From the schematic (Page 6)  it looks like the board and the gas valve both have EFT's on them, or the energizing of the gas valve is what sends 24v back to the board to activate the blower on relay.
https://customer.hon...00s/69-1270.pdf
28 January 2013 - 02:20 PM
The Delay on is set to 30 seconds
The delay off is set to  140 seconds, both are default settings (I have tried the others) From what i have found the gas valve has a terminal for EFT (electronic fan timer) that is supposed to energize when the gas valve opens and de-energizes when the gas valve closes.
I havent measured there yet to see if that is working, that is probably the culprit.
In Topic: AC Compressor wont kick on
31 August 2010 - 04:19 AM
I ohm'd out the cap and the compressor side was Zero, I borrowed a cap from another unit plugged it in and the compressor started. I found the problem (bad capacitor) now I have to figure out what size it is, there is no writing on it. It is a Dual Run, Fan and compressor.
In Topic: Buying New Fridge
27 May 2010 - 02:41 PM
She is looking at a LG as I type, trying to move her to the Maytag MFI2569VEM0
