gregger77
Member Since 01 Jul 2007
Offline Last Active Oct 29 2012 05:17 PM
In Topic: GE XL44 Gas Range: On All Burners, No Spark
26 October 2012 - 03:30 PM
Thanks, will get out the meter and check this weekend. Is there a way to rule out the wiring from the burner switches to the module?
-- G.
In Topic: YouTube of my Noisy Motor. Too Noisy?
19 October 2012 - 01:47 PM
Or just replace the motor when the noise becomes unbearable
Yup, that's the current plan! I do frequent eBay and have found "good" used motors for about $60. Craiglist, I never thought of for appliance parts because it's not set up for non-local buying.
In Topic: Goofed the Whirlpool lid switch wiring?
18 October 2012 - 09:43 PM
Well, turns out I bought a Cherry E13 switch that is set up as NC. See picture attached.
(I guess there are different submodels of the E13). Even though there is a space for a NO contact, it's empty and there is only an NC and a COM contact.
I will see if I can move the contact itself out of the NC space and into the NO space; if not, I'll buy another switch.
10 October 2012 - 11:47 PM
Thanks jb for the additional explanation on the basket! I did pull the agitator and found the spin tube perfectly aligned with the drive block ears, all in great shape, nothing out of position. I also shone a bright worklight against the translucent tub and saw no extra socks or sneakers in there.
The motor is noisy, for sure, as the You Tube video shows, but I don't know if the noise is related to a functional issue that might create occasional added resistance. My wife ran about four heavy loads of laundry today (it's a large-cap machine) and the thing ran like a champ, motor chirring away.
We will keep an eye (ear) on it! If other issues develop, it may finally be time to buy that spanner nut tool.
Thanks again.
09 October 2012 - 09:53 PM
Feedback has gone quiet, so I'll wrap this thread by saying, I cannot seem to find any reason for the motor to have stalled. I did clean some rust out of the pump shaft area, so maybe the pump will turn a little more freely. I don't know motors well, but the noise heard in the YouTube video I posted seems to be a noisy bearing. It only makes noise at low speed, not high speed. Start switch and capacitor are fine; coupler is perfect.
So, I'm repairing the Cherry E13 switch inside the lid switch assembly (which I'd jumpered a while back) and am putting the machine back together and letting Wifey have at it. A full test load of laundry ran flawlessly this a.m. except for that low-speed bearing knock.
I'll observe carefully as I can over the coming days and see if the failure occurs again. I'll post if it does, hopefully with more detailed symptoms.
Thanks all for your help, I really appreciate it!! :yes:
-- G.
