TLC917
Member Since 10 Jul 2007
Offline Last Active Jan 25 2013 04:14 PM
In Topic: GE refrigerator PSS27SGMDBS too cold
25 January 2013 - 03:21 PM
Many thanks for the manuals. I apologize for taking so long to reply.
08 November 2012 - 07:39 PM
I have same issue with model PSS27NGMDBB. Could you send service manual so I can run diagnostic as well? Thank-you Samurai.
In Topic: Kenmore Ice Maker on the Fritz 106.52542101 White side X side
04 February 2010 - 12:18 PM
Ok, we can stop trying to reassemble the valve components. I persisted searching the database and found the Kenmore troubleshooting guide which indicates the solenoid is bad on the icemaker supply line. THANKS for trying to help. Ordered the new part.
04 February 2010 - 06:49 AM
I have confused you because we're not on the same page. I have no difficulty reconnecting the valve assembly to the hoses. My issue exists in knowing which order and in which side to put the parts located *inside* the valves. I took it apart to make sure there was no sediment blocking the flow of water. That's when I had the unfortunate sudden pain in my back and the thing dropped out of my hand before I could get the parts listed as to which went where. Does that make the muddy water any clearer?
03 February 2010 - 05:17 AM
Yessir! Sorry I didn't state it that way. Wanted to make sure you had the correct one to give assistance. New part may be exactly same inside, but I don't know that. Thanks for your help. The solenoids are green and blue (think that's what they're called).
