Stan03
Member Since 04 Aug 2005
Offline Last Active Mar 30 2012 09:48 AM
In Topic: evaporater restriction
05 January 2011 - 10:35 PM
Hey thanks for response,
The compressor was completely lock up. The low side pressure ends up in a -10psi vacumn. Whats funny is the presssures equalize well with in the 10min limit.
In Topic: maytag ice and water control panel
12 October 2006 - 06:02 PM
Thanks for the suggestions!
I know they are not related to the current problem, but what are the purpose
of the primary and secondary water fill valves? I'm used to seeing just the one!
Thanks again
Stan03
In Topic: whirpool direct-drive
23 May 2006 - 03:14 PM
Hello,
I took the motor out of its mounts and tried as you suggested, still the same
humming noise from motor only. While observing, I was able to get the motor
running by turning the motor shaft a couple quick turns.(tried extra motor with
the same results).
Hopefully this info will help?
