jambatt
Member Since 12 Jul 2007
Offline Last Active Jan 14 2015 12:20 PM
In Topic: GE Side by side Refrigerator Model PSC23MGPABB Freezer issue
31 December 2014 - 05:39 PM
Have you placed thermometers in both sides for accurate temp readings. If so, post temp readings.
29 December 2014 - 06:51 PM
Is evaporator fan running? Is evaporator coil frozen over? If fan is running and evap coil is frozen, could be bad defrost heater or could be bad control board or thermistors.
In Topic: Frigidaire F/L Washer, Model#FTF530FS1, water leak on syphon fill
20 December 2014 - 02:02 PM
Check #39 on control panel parts diagram. Have run across several similar leak problems with GE. Plastic fill duct splits at seam.
In Topic: LG Washer WM2655HVA / 204kWRE80390 shuts itself off randomly
12 December 2014 - 06:01 PM
Check the thermistor.
In Topic: GE WCSR2080B2WW doesn't spin
13 November 2014 - 07:08 PM
Dremel works great for this!
