jambatt
Member Since 12 Jul 2007
Offline Last Active Sep 12 2014 06:26 PM
GE Dishwasher GDF520PGD0WW
06 September 2014 - 07:54 AM
Unit fails to fill with water. Water to valve. Entered error mode. Door status OK. No error codes shown. Service mode test shows no power(13.5vdc)to water valve. Continuity on valve coil and reading 30 ohms. Tech sheet doesn't show ohm value for valve. Flood switch OK. Conclusion: Bad control board. Anything else in circuit to prevent valve from opening?
GE Washer GFWH2400L0WW
11 August 2014 - 06:35 PM
Dryer sits on top of washer. Can washer control panel be removed without taking dryer off washer??
GE Washer GFWH2400LWW
09 August 2014 - 04:52 PM
As usual, customer replaced a Friggy made laundry center with a Front loader with the dryer on top. Power to unit. Shows no power light when power button depressed. Door latch seems sketchy. Can't run diagnostics since unit won't power up. Would bad door latch keep unit from powering up?? Can access door latch without removing dryer but gotta' have help to remove dryer to get access to control board. Price of doing bidness just went up!
GE Dishwasher GLD4550N10CS
08 August 2014 - 06:12 PM
Anyone know the voltage and uf of the pump motor capacitor? Have used capacitor from a GE microwave exhaust fan motor before but don't remember the rating.
GE Range JBP21G V2WH
29 July 2014 - 06:35 PM
Customer said oven worked fine for first cake but then wouldn't heat for second cake. Oven On light is flashing and broiler element is warm. Bake element does not come on. Suspect control. Service manual doesn't address flashing Oven On light. Anyone got a better idea??
