jbmcq
Member Since 01 Sep 2007
Offline Last Active Jul 22 2014 12:32 PM
#210368 Is there a whirlpool model that matches this Kenmore 110.20912990 model #
Posted by jbmcq on 07 October 2011 - 12:54 PM
Reg Us,
The WHIRLPOOL /w/ the timer problem never hums ,from the way it acts my guess would be an open in the drain or spin circuit. Just trying to verify HOW to test for that. I was testing it with a jumper in the lid switch harness / did not check to determine jumper working properly / just assumed ( yes I know what assuming does!)/so that is possibility / (no continuity to allow drain spin cycle to work) Will check + let you know.
The KENMORE is the one with humming motor, I found how to test motor windings ie/ low speed 2.9 ohms according to schematic.so will figger that out .
this is the washer I was wondering if the speed cycle switch could cause similar symptoms / HUM. My guess is there is a way to check continuity through the speed cycle switch ?
We should take ol K DOG out + give him a Little WHAT FOR for causing the confusion re the posts :deal: . HA !
