foogoo
Member Since 01 Sep 2007
Offline Last Active Jun 21 2013 12:13 AM
In Topic: GE Prodigy dryer part identification help
16 June 2013 - 10:32 PM
That would be the right part. Don't forget the drum glides listed on the same page. 2 of each. White ones on the sides, dark ones on the top.
Great, thank you!
In Topic: Magic Chef Gas Range 34JA-3TKXW
15 August 2008 - 03:23 AM
[user=36]Budget Appliance Repair[/user] wrote:
Most likely a very simple repair.
Remove all four burner caps and then with a sewing needle, clean all the gas orifaces out.  This style of burner over the years will accumulate a buildup of gookus in the port of the oriface making it smaller, hince the small flame and sometimes can't get the burners to light with the electronic ignition becuase gas volume has been cut down so much.
Just don't drop the needle all the way down into the oriface and gas line were you can't retrieve it.
That's what I already tried. I removed the burner tops and all the holes appear wide open and unclogged. Could there be buildup somewhere else down the line? Thanks.
14 August 2008 - 06:49 PM
[user=3641]RegUS_PatOff[/user] wrote:
What's the history of this range ?
Has it always acted this way ?
Has it ever been converted to LP ?
-Not much history other than it's old, approaching 20 years. Saw moderate use throughout it's life.
-Started with two burners, then three, and now all four produce only small flames.
-Never.
Thanks for any help you or anyone else can offer!
