dan-c
Member Since 04 Sep 2007
Offline Last Active Feb 11 2013 04:44 PM
In Topic: LG Center Burners
15 January 2013 - 12:25 PM
Change which orifice??..........The   9100 BTUH ??.........or the 17000 BTUH ??..........The gas valve may not be correct for the replaced orifice..............You are not going to change a part that well  paid, highly trained  engineers have perfected for you, are you????
Welll, ummm, err, I was going to change the center burner 9100 to a 12000. If it's not as simple a matter of replacing ill or low performance designed motorcycle or auto parts that well paid, highly trained engineers developed I guess not.
If I want more BTUH to make my cast iron center burner griddle more useful than a warming rack without causing harm, why yes, yes I am :wink:
Gas valve? Dang, always a curveball
15 January 2013 - 09:36 AM
It is and has always been natural gas. The spec's say the center burner is good for 9100 BTU while the LF is 12000 and the RF is 17000. I think 17000 is too much, I guess I'll change the orifice to the 12000 and hope for the best.
Since it's GE made (ugh, had I known that :unsure: ) I suppose the GE spud nut orifices will work?
14 January 2013 - 05:31 PM
Model  number?
Usually, the metering hoods can be removed and cleaned.
It's an LG LRG3091ST only about 6 months old and it's all clean. The brass orifice looks small compared to all the other burners except the tiny warming burner.
My question is can I replace the center one with an orifice that passes more gas :)
The burner covers (metering hoods?) seem to all have the same size holes too
In Topic: Another Water Dispenser Not Working GSH25KGPCWW
14 May 2008 - 02:33 AM
Sorry for the long wait. I forgot about the fix once it worked. The part was easy to install and works as designed. It did take about 24 hours to thaw but I think that can be expedited if you leave the light on in the dispenser door. I have not had any more issues since the install which was about a month ago.
Thanks again to Pegi and the forum for advice.
Dan-c
05 March 2008 - 01:10 AM
I sure will. Thanks again. Now all I need do is wait for the part.
