dan-c
Member Since 04 Sep 2007
Offline Last Active Feb 11 2013 04:44 PM
LG Center Burners
14 January 2013 - 12:25 PM
Is it advisable by you learn'ed ones to replace the center burner orifice on my LG stove (and what general size)? It simply does not get hot enough to cook/sear properly on. If I place the griddle to one side or the other I get enough heat to cook steaks or whatever but not the center burner (which I 'thought' was its purpose).
Thanks!
Another Water Dispenser Not Working GSH25KGPCWW
04 March 2008 - 08:36 AM
2004 GSH25KGPCWW Water in door stopped working after 3 days away from home. The water valve is cycling (coming on when the paddle is pressed). Ice maker works fine (the valve was replaced last fall). The water coil behind the vegtable drawer is not frozen. Any thoughts?
