TRIT0N
Member Since 20 Sep 2007
Offline Last Active May 17 2011 07:17 PM
In Topic: Whirlpool WFW9600TW01 Washer Door boot seal replacement
17 May 2011 - 07:16 PM
gotta say all the boots i have replaced on every brand available i have never had the need to remove the front, i have however had to cross town in rushhour to help other techs get it done
In Topic: Fisher Paykel DD603
25 February 2011 - 12:36 AM
i have had alot of drainhoses crack on these models, inspect that first
In Topic: Frigidaire FDB2415LFS0 Worst D/W EVER!!!
25 February 2011 - 12:34 AM
either arm will still spray water, i think the issue that needs to be adressed first is the no draining, dirty old water doesn;t wash dishes
In Topic: Magic Chef Gas Stove 83LK-3K
03 February 2011 - 11:04 PM
the glass top would be glued to a frame that would be screwed to the box, access would be by removing those screws, the valve are ussually servicable, thouroly clean and then reassemble, bubble test after. of course you turn off the gas first before anything.
In Topic: Frigidaire Range Door Lock Problems
28 January 2011 - 12:56 AM
does your range have a control lock? many frigidaires do and they will say LOC on the display, there will be a button to push and hold to release this feature, consult manual if unsure of button
