TommasoPrimo
Member Since 20 Oct 2007
Offline Last Active Oct 12 2011 03:23 PM
In Topic: Frigidaire Gallery Dryer, FSF747GES1, Auto Dry Mode Didn't Stop...
19 June 2009 - 08:20 AM
Hello, BrntToast, are you there? Anyone?
03 June 2009 - 04:43 PM
Hey there, again. Finally found my multimeter and checked the resistance (see pic) and it was 3k ohm.
Would this be enough to cause my problem?
-Tommaso
31 May 2009 - 07:53 AM
Looking at the diagram more closely, I only see two resistors:
- a 2.4k ohm one on the fabric selector switch
- a 7k ohm one on the control thermostat
See pic
Is it one of these that I need to measure? If so, do I take the attached wire leads off, or measure still connected?
Thanks for your help.
-TP
29 May 2009 - 12:45 PM
Mr. Toast,
That part of the diagram is labeled "Timer Motor", and has an "E" at one input and an "M" at the other. I see on the back of the timer itself similarly labeled points. I assume these are the two points between which I should measure the resistance. Right?
Re the lint, there was a fair amount below the lint screen as you suggest, but not enough to block the airflow. I ran it again, and there is a strong vent exhaust flow through the ductwork and out the eave on the side of the house.
-TP
26 May 2009 - 03:49 PM
Sorry, just double-checked and the model number is FSG747GES1.....sorry about that.
