lrning
Member Since 22 Oct 2007
Offline Last Active Jul 27 2013 02:18 PM
Kenmore refrigerator model 795.51312.012 no ice
20 July 2013 - 02:07 PM
Hi
I have Kenmore refrigerator model 795.51312.012
  it does not have ice or making ice.
cold water does come out.
can any help with a checklist to check?
 or may be something simple, because I google and there are two other questions with same issue, an there is no answer.
Oven and preheat green LED on then Off Frigidaire model FEF365BGWE
18 June 2013 - 11:14 AM
I have glass top stove and oven
  model FEF365BGWE
  Serial n F11611085
  the top surface works good.
 the oven bake,I press and set at 350 degree, it just flash the green oven LED On and the pre heat green LED On,  after that
   the temperature 350 degree switch back to the clock status.
 no heat and or notthing warm in the oven.
where should I look.
 i opened the back panel,  all wires are in good condition, opened the printed circuit board area , all wires look ok, no burnt smell or smoke
thank for any help
central air conditioner, outside fan runs, but not hot air
12 May 2013 - 02:26 PM
hi
we have installed a new outside unit and new air handler about 19 months.
the outside fan runs, but it does not blow out hot air.
we are in FLorida, summer is coming fast.
how do i troubleshoot?
thank you in advance
kenmore stainlessS model 790.96123407
23 November 2011 - 04:01 PM
I need to replace the front glass to protect children hands.
I try to remove the front door, but it is very hard
please help me with instruction to remove front door
or instructions for replacing front glass, not the glass inside
thank you
i am not a tech so a lot of nervousness.
Frigidaire electrolux model PLHS268ZCB1
14 July 2011 - 09:22 AM
have this fridge
warm both side
follow flow chart troubleshoot
serial number LA31713382
condenser fan running
vacuum condenser to clean
compressor touch warm not very hot
feel like compressor is not running
how do I test voltage at start relay
I see the capacitor, how do I get into the start relay. need part number of start relay to order
How do I know that start relay is the issue
what voltage should I read?
Thank you very much
