Seanessey
Member Since 25 Oct 2007
Offline Last Active Mar 05 2015 09:40 PM
In Topic: Maytag bravos MVWB300WQ1 throws UL @ 9 mins
14 July 2014 - 09:40 AM
Scott,
Thanks a TON! I tipped it over, and while it wasn't loose, it wasn't exactly tight either. I tightened it up good, and it's running like a beast again. I greatly appreciate the help, and bow before you most humbly  :thanks:
In Topic: monitor problems
22 August 2010 - 08:16 PM
Yep, the monitor is going bad. Pick up a new one. When you hook it up, you will realize immediately how bad your current monitor is!
In Topic: 417.44042400 Wires off motor connector (male)
22 August 2010 - 06:35 PM
That would be correct. Honestly, I'm not sure how proficient I would be at reading it. I lack the tech data sheet, so I'm flying blind on these 2 wires.
In Topic: Frigidaire made Kenmore 417.44042400
08 August 2010 - 05:11 AM
I swear, this machine needs an exorcist. Yes, it was pumping all the water out. It seemed to be pumping longer than it normally would. To be absolutely sure, I asked my wife to do a load of laundry this morning that I intended to pull out when it didn't go into the final spin. Well, she's done 5 loads of laundry, and the machine is working fine. I'm at a loss!
In Topic: Kenmore front load washer 417.44042400
12 February 2010 - 11:44 AM
Yes, I removed the boot from the drum when I was taking the drum out, and to put it back on the drum I unbolted the weights, removed them, put the boot on and then reinstalled the weights.
