gcw1
Member Since 11 Dec 2007
Offline Last Active Jun 23 2014 12:33 PM
In Topic: GE M#GTWN4950LOWS washer
23 June 2014 - 12:33 PM
Would the pressure switch cause this??
In Topic: MAH2400Aww LE code
02 May 2013 - 06:58 AM
The LE code appears when you apply power and it locks the door. I can't get far enough to do a fill test. I think the washer thinks it is full. I can't get any ohm readings on the pressure switch all contacts are open.
In Topic: Whirlpool WFG374LVB1 DSI
27 February 2013 - 01:21 PM
I checked the wiring and the polarity is correct!!
25 February 2013 - 09:20 AM
Both gas coils ohm out within range. broil doesn't work either keeps trying to start but no visual spark.
In Topic: Whirlpool Washer ATW4475XQ
07 August 2012 - 11:42 AM
It shows a hot wash but it allows cold to enter as well. No change in temp from hot, warm and cool.
That is the same diagram that comes with the washer and shows 1 speed. Do you know what this 2 speed combination means?
