NCARepair
Member Since 23 Dec 2007
Offline Last Active May 24 2015 09:23 AM
In Topic: Maytag MFI2569YEM0 Lights on, nothing else
08 May 2015 - 07:05 PM
Thought about that, those connections are on J1 also. Should get something from the display even so. If new boards do the same as the previous I Usually suspect wrong diagnosis and not a bad board. I have been in houses with these units and they had blank displays and we're not able to use the dispenser and adjust the temp. I think these boards will default to a predetermined setting when the display board/user interface is out.
08 May 2015 - 06:32 PM
Well installed HV board and Evan motor. Same result. Blank display and interior lights working. Have 120 volts at J1 red & white. No 12 vdc at J6 pin 2 rd/bk. Tried disconnecting display board thinking it may be grounding out but still no voltage out of board. Any suggestions?
06 May 2015 - 07:49 PM
OK then,Thanks.  I will report back.  Good video clip Durham!
In Topic: Amana AFD2535DEW refrigerator w/ french doors
06 May 2015 - 06:46 PM
Go slow and gentle and turn the control to off. Listen for the compressor to still be on.  If it is, tap the bottom of the control housing with a screwdriver handle and see if it unsticks the relay for the compressor. If it does, order board like Bryan said to fix it.
In Topic: old ge double oven parts
28 April 2015 - 07:22 PM
Some of the old ge elements have the part number on it. Pull it out and check it out.
