ddunk1946
Member Since 26 Dec 2007
Offline Last Active Apr 26 2013 09:13 AM
In Topic: Whirlpool Duet GHW9150PW0 water drip into tub
26 April 2013 - 09:13 AM
Update: Speaking of unplugged...when Herself returned home, I told her of the events and that I would get another valve, etc. When I got home the next day, I noticed that the drip had stopped. When I mentioned this to her, she allowed as how she had unplugged and plugged the washer.(no mean feat as they are up on pedestals and the back edges are under wall cabinets). When asked how she arrived at that, she said that whenever her fax at the office (a big Savin color printer/copier/fax server) acted up, she had to do the same and reboot it.
Sheesh. Go figure.
21 April 2013 - 08:44 PM
Yep, that's the valve. I'll get one ordered, thanks!
In Topic: Whirlpool Duet gas dryer model # GGW9250PW0, s/n MS0303753 no heat
30 November 2010 - 08:47 AM
Probably should post to this new forum (finally back in town). Bought a box of crucial parts (for the NEXT time!) but replaced the gas valve solenoids first. That did the trick!
Many thanks, all is well here again! :D
21 November 2010 - 07:30 PM
Yep, that's kind of what it seems. I was looking at the video of them earlier. Will give it a shot, thanks!
21 November 2010 - 05:55 PM
Well, this is embarrassing. I thought I'd try to start it and time the ignitor attempts when I realized I did NOT have the cabinet back to gether.
I had the blower cover and lint screen out. I replaced both of those and ran a cycle and it's been running and drying with a steady flame for over 10 minutes. Keeping my fingers crossed.
But, when I replaced the thermal fuse, it was all together when it finished a load and then went cold again. Maybe the removal and replacement of the various sensors to inspect, gently clean and test helped a bit?
Sometime later...well, false alarm. It dried the sheets, but seems like it was on about 20 minutes (my wife like the timed dry) and when I checked it less than 10 minutes later, it had shut off, but the sheets were dry. She pulled them out and turned them inside out (fitted king sheets) and put them back in to finish drying.
This time, the ignitor came on, but there is a loud click, no gas, and the ignitor turns off. I timed the ignitor and it seems to try every minute or so, but no gas to ignite.
Tried it on 'normal' mode, but the same; ignitor attempts but no gas.
