jnooley
Member Since 24 Jan 2008
Offline Last Active Oct 01 2012 06:30 PM
In Topic: Jenn-Air W181 Electric Wall Oven won't heat
01 October 2012 - 08:34 AM
OK, thanks. I'll check voltages and report back. ty! -Jim
30 September 2012 - 08:46 PM
Thanks guys. I guess that is possible. I had a working wall oven that I pulled out with Red, White, Black and Ground wires. I cut the wires from the old oven and then reconnected them with wire nuts to the same wires on the new stove Red, White, Black and I took both ground wires and connected them to ground on the junction box. So, I'll admit I'm not an experienced electrician but I figured as long as I went Red-to-Red, White-to-White, Black-to-Black and made sure the ground wires were tied to ground I would be all set. Let me know if this sounds reasonable or if I am missing something obvious. Thanks. -Jim
In Topic: Sub Zero 550 condenser fan stalling
24 January 2009 - 05:16 AM
Got the part, installed it and all is well. The fan is cranking now! You guys are great. Sending $5 more for the beer fund. Wish I could send more but things are pretty tight right now. Thanks a ton!
20 January 2009 - 03:40 AM
That's the part. Thanks for the help finding it. I overlooked that first section labeled "Belt / Motor / Pulley / Motor Coupling" :).  I'll be sure to post when I get a chance to replace it. Thanks again.
19 January 2009 - 05:39 PM
Much appreciated advice. I couldn't seem to find that part at repairclinic.com. Is there an online parts store that you would recommend for that part? Thanks.
