DylanConner
Member Since 27 Jan 2008
Offline Last Active Jul 10 2014 05:11 PM
In Topic: Sealed system equipment
04 September 2011 - 12:45 AM
I have the Victor Oxy Acetelyne kit with a 00 tip, Robinaire Cool Tech 4CFM Vac pump, a slimline scale from Johnstone, and some decent Yellow Jacket gauges, and a few hand tools ie: swaging tools etc. You can find some good deals on this stuff on eBay and Amazon. You will probably spend $800-$1500 at the start and invest a little more along the way. The cool thing is: you will make good money doing the work. Many companies will walk from a Sub Zero evap or compressor change, but there is money to be made doing it, if you can do it well. Good luck, and have fun!
In Topic: Kenmore (WCI) Refrigerator leaks water
04 January 2009 - 04:47 AM
Perfect. Thanks.
03 January 2009 - 05:44 PM
Cool! I will try this. Sounds like a good plan to me. Thanks.
In Topic: Thermador double wall oven Mod#CMT20 Convert to digital clock.
21 July 2008 - 05:03 PM
That would be awesome! I am so frustrated with this thing. Thanks.
17 July 2008 - 06:40 PM
Thanks for checking, but I have those instructions. They only explain how to remove and install the buttons. I can't understand why Thermador would not send wiring instructions on a kit like this.
