laxdef69
Member Since 03 Feb 2008
Offline Last Active Jun 10 2015 06:33 AM
In Topic: Kenmore Elite Refrigerator Model 106.58976700 ice maker doesn't work
10 June 2015 - 06:33 AM
ok...for some reason after jumpering out the H T terminals, the icemaker has started working again...very weird...I'm leery of magical fixes like this, sounds like I should be expecting this to fail, right?
09 June 2015 - 09:06 AM
ok, my only thermometers are celcius.  Freezer is set for 1 F, or -17 C.  Thermometer reads below -10 C...believe that all's ok with thermostat?
09 June 2015 - 08:57 AM
Power then is getting to the ice maker so it may be a bad thermostat if the ice maker motor started when you jumpered it out
Aw crap, the thermostat isn't at all what I thinking...lol...freezer temp is good, doesn't vary much (assuming so since foods with sugar don't frost) and prepared dishes which have salt are solid, too.
I'll put a thermometer in and report back...as always, thanks guys!
09 June 2015 - 08:37 AM
Thanks guys.  Optics are fine.  I removed and jumped out the H and T terminals.  Didn't hear anything after waiting for about 5 minutes.  Came back and the tray was filled with water... Guess that means the valve isn't bad.  Are you thinking that because it worked while jumpered out that the module is bad?
Thanks again!
08 June 2015 - 09:46 PM
Found it after looking around...thanks...you guys are great IT support too!
:woot:
