smokehouse
Member Since 19 Feb 2008
Offline Last Active Nov 20 2012 11:34 PM
In Topic: No heat! Trane XE80.
20 November 2012 - 11:37 PM
Thanks for the help, gentlemen! That furnace is working just fine, and I've learned something new. Have a great Thanksgiving!
14 November 2012 - 08:49 PM
Found that part and cleaned it, Bullstok- although it seemed clean. So far all seems well! Thanks for your help, Jumptrout and Bullstok! Will keep an eye on it! Will donate to the beer fund!
14 November 2012 - 07:34 PM
Thanks for the replies, gentleman! How does one go about resetting the rollout switches, Jumptrout?
14 November 2012 - 01:24 PM
Now getting error code- "system lockout, no flame, check polarity" after several failed attempts to keep burners lit!
14 November 2012 - 01:12 PM
Thanks for your time Jumptrout! What does this part resemble? I see a small resistor-like part coming out of a ceramic mounting base about 6" away from the burners (says "microtherm" on it). My meter show continuity through this part at all times, regardless of the burners being on or not. Does this sound like the part to which you refer? OR, would it be the part that seems to be mounted on the sheet metal above the burners (has "Texas Instruments" on it, if that helps) that's wired in series with the other part I mentioned earlier (as well as a diaphragm switch), and is a rectangular shape about 1.5'X2.5"? Thanks again for your time!
