Member Since 24 Sep 2005
Offline Last Active Mar 18 2014 02:03 AM
In Topic: Kenmore Laundry Center Gas Dryer no Heat
17 March 2014 - 05:25 PM
anyone have a wiring diagram for that model ?
Wiring diagram
PART NUMBER: 131000500
OR
Parts catalog
PART NUMBER: 5995241113
In Topic: Kenmore electric stove trips main
17 March 2014 - 12:16 PM
did you see my previous post ?
In Topic: Timer problem
17 March 2014 - 10:57 AM
... I don't have that type of thermometer.
local hardware store would have one ...
Any type that can read those temperatures . . .
I can't help diagnose the problem without the actual Vent air temperatures
16 March 2014 - 08:32 PM
Dryer Vent 4" diameter
Vent should be rigid metal.
Short lengths of flexible metal may be OK, if not crimped when moving the Dryer into place.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
With an empty load, Timed Dry, High Heat, the vent temperature should cycle somewhere between 135F and 160F
Check / clean the Dryer Vent
Disconnect the Dryer Vent and check for good air-flow there and where it exits the house.
Check the Vent air temperature at the back of the Dryer.
If you have a Harbor Freight Store near you,
 $ 3.99 sometimes on sale for $ 2.99
http://www.harborfre...eter-46586.html
16 March 2014 - 06:01 PM
... The other day I noticed that timer wouldn't advance in auto dry permanent press and auto dry regular fabrics cycles.
with the Temperature Switch set at Regular OR set at Delicate ?
also, what are the actual Vent air temperatures at the back of the Dryer.
Should cycle between two different hi and low temperatures, depending on the Temperature Switch setting
Delicate 140F to 160F
Regular  150F to 175F
