Member Since 24 Sep 2005
Offline Last Active Mar 18 2014 02:03 AM
#288035 Amana Electric Dryer has element the same as Samsung
Posted by RegUS_PatOff on 15 March 2014 - 09:18 PM
35001247
NED7200TW
MDE6700AYW
DC47-00019A
DV203
DV206
DV209
DV210
#287784 Kenmore (Amana) 596.50692000
Posted by RegUS_PatOff on 14 March 2014 - 09:59 AM
uses (2) Dual Water Valves
Dual water inlet valve, primary (before water filter).
Replaces problematic plastic “Y” connector, includes instructions
Manufacturer Number 12544001
Water inlet valve for icemaker/water filter, secondary (after water filter)
Part number: AP4013367
http://www.repaircli...lve-Float-Parts
http://appliantology...heets-t13063r1/
including water routing
Amana Refrigerator
Tech Sheets T13063R1
ARS2364A
ARS2364A
ARS2364A
ARS2664A
ARS2664A
ARS2664A
DRS2362A
DRS2362A
DRS2662A
DRS2662A
PARS2364AB0
PARS2364AC0
PARS2364AW0
PARS2664AB0
PARS2664AC0
PARS2664AW0
PDRS2362AC0
PDRS2362AW0
PDRS2662AC0
PDRS2662AW0
#287775 Kenmore 800 mystery...
Posted by RegUS_PatOff on 14 March 2014 - 09:11 AM
parts from Amazon, and also their "3rd party" suppliers,
have known to be defective, or not OEM
new Switch part number ?
If the switch fails, make sure the drain hose is positioned at least 42 inches from the finished floor
and is discharging into an open stand pipe or laundry tub in order to prevent water from siphoning which can damage the switch.
any part ordered from RepairClinic OR Appliance Parts Pros
can be returned for a refund (less shipping)
#287471 Asko 7005 dryer - need help identifying problem
Posted by RegUS_PatOff on 11 March 2014 - 02:33 PM
how's the sections of the Heating Element ?
one or more may be broken / grounded
http://www.repaircli...?R=154&N=763732
Heating-Element-Assembly-8056060-0085486
#287456 Frigidaire Tonight (ie Phil Collins as an Appliantologist)
Posted by RegUS_PatOff on 11 March 2014 - 12:24 PM
All I can toss is my jeans but then I would be naked, nothing underneath.
Yea they get the whole crack & nothing but the crack.
aahh . . .  'Frigerator Repairman
th?id=HN.607999062305473025&pid=15.1
#287427 Frigidaire Tonight (ie Phil Collins as an Appliantologist)
Posted by RegUS_PatOff on 11 March 2014 - 08:52 AM
.. I don't have any panties to throw on the stage, either
commando !
#286991 Jenn Air PRG4810NP Gas oven won't heat properly
Posted by RegUS_PatOff on 06 March 2014 - 10:49 AM
sounds like a weak "glow ignitor"
common problem, they get weak
Part number: 73001165
#286921 GE Dryer DCVH680EJ0WW not drying long enough on Moisture sensor cycles
Posted by RegUS_PatOff on 05 March 2014 - 12:52 PM
when drying a small load, if the wet clothes don't tumble across the Sensor Bars,
the Controller will think they're dry
#286609 Kenmore 70 series washer
Posted by RegUS_PatOff on 02 March 2014 - 08:26 PM
Pressure Switch Tubing may have a crack, became brittle, or clogged.
If the Tubing has ever been disconnected,
the Washer must be completely empty of water before re-connecting.
#286417 Jenn air cooktop jed8430adb
Posted by RegUS_PatOff on 01 March 2014 - 11:10 AM
... install hasn't changed except maybe my wiring
... I only have 3 wires blk, wht, and grn
... it say it is a 120/240v
... A three-wire, single phase, A.C. 120/240 volt
1) ? ? ?
2) you only have a 2-wire (plus ground) supply = 120v
3) 120 & 240 v supply needed ..
which means it needs both voltages.. 120v 2-wire won't work . . .  240v 2-wire wont work
120v for the Controller & Lights
240v for the Heating Elements
Gas Ranges only need 120v
#286338 Jenn-Air SVD48600W Downdraft Range Problem
Posted by RegUS_PatOff on 28 February 2014 - 12:42 PM
... Long story, but I'll try to keep it short.
... I ran the clean cycle ...
:woot:  :nono:
#286337 Frigidaire FL W FTF530FS1 tumbles, but no (high speed) spin
Posted by RegUS_PatOff on 28 February 2014 - 12:32 PM
Quote from a previous thread:
AccApp wrote:
First rule: It's not the timer.
Second rule: It's probably not the timer.
Third rule: It could be the timer. But rule out all other possibilities first.
I have yet to replace a timer in a Frigidaire built f/l washer,
the one I almost did had one of the timer harness plugs knocked loose by an out of balance load
#286084 electrolux model EIED55HMBO
Posted by RegUS_PatOff on 25 February 2014 - 10:04 PM
does the dryer get hot if you run it in a air dry cycle
I would also like to know.
If no heat, then, starting with a cold Dryer,
open the Door and then start a normal heat cycle with the Door open.
I won't run, but is there heat ? (shouldn't be)
#286021 Kenmore dishwasher Blinking lock light 665.15979992
Posted by RegUS_PatOff on 25 February 2014 - 12:32 PM
CONTROL LOCK:
The Control Lock feature (and light) can be turned on or off by the customer at any time
by holding down the Air Dry option key for 4 seconds.
> unless, of course, the Air Dry Key is stuck:
ERROR MESSAGES
STUCK KEY:
If the control detects that a key is stuck in the depressed position,
dishwasher operation will be suspended and the control will flash the light for that key until the condition is corrected.
If a key without a light is stuck or multiple keys are stuck, the control will flash the Lock-Out light.
you need Tech Sheet - 9744480
same as:
Kenmore DishWasher
665.15812990
http://appliantology...990-tech-sheet/
Part number: 9744497
#285810 Need to Understand Better How to Make a Fridge Compressor Test Cord
Posted by RegUS_PatOff on 23 February 2014 - 09:51 PM
... Will probably be up all night chasing rabbits,  lol..
In Japan, rabbit chase you
