certified tech group 51
Member Since 10 Mar 2008
Offline Last Active Yesterday, 06:39 PM
kenmore refer M 253.44333604 Missing tech sheet
22 July 2015 - 10:21 AM
At least they left the wire diagram..............Been looking at Frigidaire  service manuals....................Cannot find anything close to this unit......On the 'In-door dispenser' has two analog thermostat gauges....Open fresh food door and it has electronic controls.........Trying to cross match using the control panel main control board as a guide, went thru the first 50/60 models listed and none had the gauges in the dispenser panel..........Complaint:    Warm fresh food section......No water dispensed at door.................No idea  on how to put unit into diagnostic........Down loaded  publication 5995413142 and 5995501516..........Hoping to get one of the control systems to work for diagnostics...........Beta and Gamma controls...........
Electrolux range....EW30DS65GS6..F-14...
13 July 2015 - 10:27 PM
Will be going out on this unit soon............Cannot find any info on this unit...Dual fuel..............I have the service data sheet.................Cannot find any way  check from touch pad to the controller.......F-14..Misconnected keyboard cable......It sez if the cables are good, replace the touch panel.........pricy test, the touch pad goes for 665 Clam$.............Then it sez, if that don't work,  replace the controller, another 225 Clam$.............There 's gotta be a better way.... :kopkrab: ..................
Who want's free stuff
16 June 2015 - 08:21 PM
Moving out of my storage bay........Stuff too good to toss out, ( Plus I would have to pay the dump fees :woot: )...would like to sell for a few dollars, but will take forever......So it is easier to give it away..........About 8 new O.C.U.s........( 2)  Used coin-op dryers electric with coin boxes and keys............used J/A gass cook-top.......used Heartland double wall oven.........Plus other appliance stuff.......... On the Oregon coast, about three hours south of Portland........ Gotta be out by the last weekend of June.......P.M. for info........
Miele D/W # G2170 intake/drain light flashing
08 May 2015 - 10:11 AM
 Do not see too many of this brand.......Only had time for a quick look.....Drains O.K.......Fills for two seconds, pause for two seconds, Light for  Intake/drain lights and starts to beep, but continues to  fill for two seconds, pause for two seconds.......... Only had a partial service manual......Cleaned the filter at the intake water valve, removed the left side panel, no restrictions in the water diverter, did not hear the circulation motor start.........So I was thinking :woot: .........Is there a sensor or pressure switch waiting for a signal to start the wash cycle????    The customer had Goggled the problem and removed and reassembled some  parts... :nono: ....There was a small part in the sump area that took  a few attempt to get installed correctly, small plastic part with a steel ball inside and it  looks like the water leaks at the well worn gasket.......Down loading the complete manual ( 277 pages worth :ohmy: ) and will be looking for the section of " Sequence of Operation".........Reading material  :geek:  for this weekend, hooking up the 5th wheel and leaving for the beach Friday noon  :bunny: :bunny: :pint1:  :woohoo: ............
K/M 11023812100 timer
06 April 2015 - 03:22 PM
This unit needs a timer...............Too cheap to buy a new one..........I have a new W/P timer P/N 3951770..........I also have a new Maytag  timer 22002820...The Maytag timer is N.L.A...................Trade for a new 3955193=661649 timer  anyone????..............did not know which heading to post this under ....... :deal: .
